Is my 400 sbc salvageable?
Old Feb 29, 2004 | 07:34 PM
smithtc's Avatar
http://f2.pg.photos.yahoo.com/ph/gta...cer1/my_photos
Nice little crack across the head bolt and to the water passage.
Above number 3 cylinder.
Can it be fixed? I'd hate to lose my money on this one. The 642 heads and 4 barrel intake that came with it aren't much consolation.
Old Feb 29, 2004 | 08:12 PM
cgb's Avatar
cgb
Guess it depends on how much u have in the engine.
It can be welded. Then it's got to be smoothed back out, and normally the block is decked.
I'd get the quote on the work, and if it's more than it would cost u to find another good 400, I'd keep if for the crank.
Every GOOD 400 I've scored comes out of a running vehicle...
Alot of trucks and vans have 'em and alot guys won't look at van motors cause they are such a pain to get out at the junkyard....
Old Taxi's, Impala's, Station wagons alot had 400's.
Old Feb 29, 2004 | 08:17 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'd run it to a machine shop to check with them, but it doesn't look good.
Looks like it will interfere with the head gasket sealing, and the crack in the water passage - also a bad thing...
But you never know.....
Old Feb 29, 2004 | 08:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a pretty common SBC problem actually, and not just 400s.
The usual cure is to drill it out and put a steel pipe plug in it, and drill & tap the plug. Then deck the block.
Some people will actually do that to all the coolant holes to strengthen the deck.
Consider this as your golden opportunity to lose the 624s. It's a blessing in disguise.
Old Mar 1, 2004 | 12:25 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
RB83L69 is correct about drilling it out etc. My machinist friend calls it "stitching."
Old Mar 1, 2004 | 11:28 AM
smithtc's Avatar
That's good news, thanks!
Old Mar 2, 2004 | 06:03 PM
smithtc's Avatar
Bad news...
Machine shop said chunk it...Not worth fixing, not unless it is some rare motor.
Hopefully the crank is still good for a 383.
Old Mar 2, 2004 | 09:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you need to find a new machine shop, that's not going to try to get you to gift them your 400 block so they can keep it for their own race car or whatever.
Old Mar 3, 2004 | 01:03 AM
Originally posted by smithtc
Bad news...
I agree...find another shop.
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
