Can't get heater core hoses off
Old Mar 4, 2004 | 08:27 AM
Mike89GTA's Avatar
Does anybody know any good tricks to get the heater core hoses unstuck? Would a heat gun help? I have one but I haven't tried it yet.
Old Mar 4, 2004 | 08:38 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
If there's enough slack in them just trim them with a razor blade. first cut the hose as short as possible then cut a line down the middle of the offending peice and it will peal right off the heater nipple.
If theres not a whole lot of slack just work a screwdriver between the hose and the nipple.
Old Mar 4, 2004 | 09:31 AM
ede's Avatar
ede
i have a set of removal tools from snap on. about all they are is a bent awl to work in between the hose and fitting, works very good for getting them off.
Old Mar 4, 2004 | 09:37 AM
conlinj's Avatar
I just cut the slit down the middle of the hose came right off after that
Old Mar 4, 2004 | 11:00 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I recently had this problem... I tried to use a bent pick as ede was saying (although the tool he mentions probably goes deeper and is designed more specificatlly)... That didn't work as well as I'd hoped... I finally ended up getting a pair of pliars and gently grabbing the hose and twisting it laterally (to break the seal)... Then it popped right off... just be careful not to tear up the hose too bad... Worked good for me..
Old Mar 4, 2004 | 11:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's pointless to save the hose, and even more pointless to risk breaking the solder joints where the hose nipples are attached to the heater core.
Just slit it lengthwise and it comes right off.
Old Mar 4, 2004 | 11:03 AM
Mike89GTA's Avatar
Ok, I got it off. I just used a big pliers to twist it loose, then they pulled right off.
Old Mar 4, 2004 | 11:05 AM
thirdgen88's Avatar
Car: 1995 Corvette
Put some vaseline or something on the inside edge of the hose when you put it back on so it won't do that next time..
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
