oil leak- help me
Old Mar 4, 2004 | 06:15 PM
Z28Clone's Avatar
oil leak- help me
Just rebuilt the motor, changed flywheels around after the rebuild. Is banging with a 2x4to get flywheel on and new pilot bearing going to break the rear main seal? I have a rear oil leak that is causing a mess around the flywheel area. Can't tell if it is just the oil pan gasket. Engine is in car and I am already changing the clutch (damn OEM clutch from Autozone)and I'd like to fix this oil leak. I don't want to drop the crank and replace the seal, which means taking off front end to get the timing gear off, etc. I just want opinions on whether or not a rear main seal is hard to break.
Old Mar 5, 2004 | 02:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
https://www.thirdgen.org/techbb2/sho...ight=rear+seal
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
