anyone used a steel shim head gasket w/ success?
Old Mar 6, 2004 | 03:17 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
has anyone out there had any experience with using a .015" steel shim head gasket like the felpro #1094? somebody said he heard bad things about them but i've heard good things. what's your experience?
Old Mar 6, 2004 | 03:31 PM
ede's Avatar
ede
you need a good finish and a flat surface more so than a composition type gasket, but there is nothing inferior about a shim gasket.
Old Mar 6, 2004 | 03:49 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i assembled my engine using steel shim gaskets, they work fine assuming you have good clean surfaces...
Old Mar 7, 2004 | 07:27 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
You'll probably want to use a spray adhesive like Permatack, just give the gaskets a shot like you're spray painting them and let them get tacky.
When I told the fellow doing my heads that I was using a shim gasket he put a finer finish on refacing them as the shim isn't as forgiving as a thick composite gasket.
Old Mar 7, 2004 | 10:43 PM
Axe's Avatar
Axe
Car: 89 IROC-Z
Good advise guys. I use them all the time and have never had a problem. Axe
Old Mar 7, 2004 | 11:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I used them when I did the mods (the stock gaskets were shims, by the way). I didn't do anything to the block but scrap off the old gasket material. The heads were new castings.
I sprayed aluminum paint on the gaskets just to be sure they sealed. They're rubber coated, but I took Felpro's surface finish warnings to heart. Been going fine since Nov. '01.
Used steel shims on the 396 as well (but used spray Coppercoat on them).
Hodge
Alternative Port EFI Intakes
85
May 1, 2013 11:14 AM
377Z
Jun 3, 2004 09:10 AM
rockind78
Mar 2, 2004 11:18 AM
PeteZ28
Jan 12, 2003 02:21 PM
crucial
Oct 9, 2001 12:52 PM
