Tons of knock retard!
Old Mar 8, 2004 | 03:30 PM
Marc 85Z28's Avatar
My car has been running slower and slower over the last few weeks, and the exhaust note is changing too much. After checking the timing, and getting all sorts of strange fluctuating readings, I decided to put it on my shops Snap-On scanner. Turns out I'm getting a good bit of knock retard. There is no audible detonation and the plugs are reading fine. I'm still running the original 1985 LG4 piece, and now have headers. I've heard that these knock sensors can be quite sensitive and are known for false knock conditions. I did a search and apparently you can't just disconnect the sensor. You must provide a resistance signal to the ECM for the ESC to work properly. My question is this: What resistance do I need for my year? Or could I just check the resistance of the sensor with the engine off, even if it may be faulty?
Old Mar 9, 2004 | 02:41 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If its just a one wire ks you wont need a resistor because that type produces electricity. If its a two wire you would need a resistor because the cpu needs to see resistance there or else it will think theres a problem.
Old Mar 9, 2004 | 08:19 PM
AM Racer's Avatar
Generally you can ground out the wire from the sensor to check. The wire can be left disconnected, but not recommended. It can work as a sort of antenna picking up stray signals and transfer to the computer.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
loud91rs
Oct 5, 2015 10:05 PM
3.8TransAM
Oct 1, 2015 07:47 PM
efiguy
Sep 27, 2015 01:30 PM
