motor size
Old Mar 8, 2004 | 03:46 PM
kituk's Avatar
Car: Ford Explorer
Engine: 4.2litre
Transmission: automatic
motor size
I recently purchased a complete TPI drivetrain from a 1988 GTA which i want to use in restoring a 1987 Firebird. It has an automatic 7oor4 transmission and has 3.27 gears in the rear. I was told that the motor was a 350 (5.7 litre) and according to the spec sheets found on this site it looks like it is a 5.7 litre, however on the bellhousing it is stamped GM 5.0l. Do I have a 5.0 litre or did GMstamp some of their 5.7 litres with a 5.0 litre marking.
Old Mar 8, 2004 | 04:02 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
sounds like you got a 305.. you could look up the casting number but it'll probably say its a 305 too.. if it really is stamped wrong the only way to actually tell would be to pull a head and measure the bore
Old Mar 8, 2004 | 06:07 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The casting# on the crank will tell also. Try http://www.mortec.com to check casting #s.
Old Mar 9, 2004 | 05:16 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It will? THe 305 and 350 share the same crank casting. So no!!
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
