major work on my car, have sum questions
Car: 1983 Z28
Transmission: TH350
hey guys my car is in the shop getting my th350 rebuilt and beefed up along with a shift kit, tranny kooler and a higher performance stall converter. i am getting one of those stock thidgen tranny cooler put in (the small one that mounts to rad)
is this cooler any good?? is it gunna help??? or is it not worth installing and i should wate till i get a better aftermarket one??
one more thing: i have a holley contender intake and a holley 750 carb. the bracket i have on now is not a good choice at all, would the bracket off a 305 lg4 work with my intake/carb or is there a adjustable bracket out there that works perfect with aftermarket holley intake and carb or a car i could get one out of at the junkers that will work???? (only cable i got going to carb are kickdown and gas)
Transmission: 4L80E/4L80E
The stock tranny cooler goes inside the radiator tank. They must be putting something else on. Typically, it's best to run the external cooler in series with the factory cooler.
Most parts or speed stores will have the kick-down bracket. Check the Summit website under carb assessories, they have one for less than $10 (plus their $7/order processing charge, of course).
Car: 1983 Z28
Transmission: TH350
ya it is an external cooler (looks like a mini rad) its 22" by 19" quite small, thats y i am wondering if it will do the job right? will it???
by any chance do u no if the bracket off a lg4 will work on my holley?? or the bracket from a LC1 v6 carb engine?? trying to avoid ordering one (need it by 2 days) and spending more money since all this work is running me 800$ canadian, not to mention i just finished spending over 1k on roh rims and tires.
thank for help me out. again lol
Car: 1983 Z28
Transmission: TH350
thanks so much! i just installed it today along with the rebuilt tranny and 2200 converter, i was worried because i kept reading get a good tranny cooler if u upping the stall. so ya everything is perfect then.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
:rockon: Thread
NBrehm
Aug 25, 2015 11:49 PM
