TPI, MiniRam, or Ramjet?
Old Feb 15, 2001 | 06:33 PM
mtx28's Avatar
right now i have a edelbrock 600cfm carb on my '74 camaro. although it is basically new(about a year), it's giving me fits as everytime i go around a corner it doesnt inject any fuel. its not the pump, bc that is about 2 weeks old. anyways, im considering EFI, but wasnt sure which direction to go. a TPI setup would be nice for the price of a used one, but i've heard complaints about its limits. I think it was guido who loves his new miniram setup(i read what he had to say on his page).. I dont konw of anyone with a Ramjet, but from what the mag's have said about it(one thing is that it wasnt built for emissions as was the TPI systems) its more suitable for me. What do you guys think? i have a VERY mild 383 by the way, soon to have a 700R4, and i have 3.73's now.
Old Feb 15, 2001 | 08:38 PM
CamaroX84's Avatar
I would go with the Mini Ram. I don't know much about the Ram Jet, other than it is expensive. I think the Mini Ram is like a grand or so. Although it is more expensive than standard TPI, the benefits outweigh the cost. You can get some serious horsepower from it. But if you can't afford it, TPI is good as well. Just my .02.
Old Feb 16, 2001 | 01:48 PM
mrls199's Avatar
Hey, I am not trying to be a smart *** or anything, but have you checked the floats in your carb? Sounds to me like the floats might be set too low in the Carb. I have a 600cfm #1406 on my 1968 Firebird 400 and it has been a great carb for about 4 years now (no rebuild or adjustments!)
Old Feb 17, 2001 | 02:42 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
If you have a mild 383, you should be considerate of the fact that it sports lots of low-end torque. The Miniram is best only if you have a free revvin' free-flowin' cammed engine. When purchased as a standalone system, the MR comes in at about $2700 unless you can cobble up the parts on your own. I'd highly suggest you look at either a hotted up TPI (with aftermarket base, runners, 52mm throttle body and 24 lb injectors), or perhaps one of the single plane offerings by Accel or Holley. They sell for about $1800. Any EFI system you buy is going to cost you $1800 when you figure in the computer, harness, sensors, injectors, aluminum, and fuel delivery system. The Ramjet might not be a bad idea, but I think it's only available as a longblock motor for about $4400.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
LT1Formula
20
Nov 14, 2015 12:02 AM
Mutillator
Sep 17, 2015 04:38 PM
The Tank
Aug 30, 2015 06:16 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
