Carb to TPI swap
Old Feb 13, 2001 | 04:28 PM
CamaroX84's Avatar
Carb to TPI swap
Ok, here's the deal. I have an 84 Sport Coupe with an LG4. I took a 350 TPI motor with the wiring harness and computer out of an 89 Trans Am. I am almost done rebuilding it. I also have the wiring harness, air filter box, gas tank, fuel lines, and the MAF stuff out of an 85 305 TPI Camaro. What all do I need to do to swap the 350 Trans Am motor into my Camaro? What problems will I run in to? ANY help would be much appreciated. Thanks.
Old Feb 13, 2001 | 04:44 PM
CamaroX84's Avatar
I forgot to mention, I have the electric cooling fans from the 85 IROC as well. Thanks.
Old Feb 15, 2001 | 03:59 PM
CamaroX84's Avatar
Also, how long did it take any of you who have done this swap? Thanks.
Old Feb 16, 2001 | 06:30 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Sounds like you have everything except for the time. Do take your time, this kind of swap should not be rushed or there will be problems. I did the same swap except mine was a 1986 SC and I used a 383 stroker.The biggest problem you'll encounter is the wiring INSIDE the car. You have an engine harness but the instrument panel harness is missing several wires. Also the fuel pump will need wires going back there. I made a diagram of the extra wires needed inside the car and behind the dash where most of the work is. Check it out here:
http://www.geocities.com/millicanga/TpiWiring.jpg
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
[This message has been edited by John Millican (edited February 16, 2001).]
Old Feb 17, 2001 | 12:20 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The '85 MAF stuff and '89 ECU and harness are incompatible. I would also like to warn you now, try and avoid any and all '85 TPI electrical junk.
"Perfection is a trifle dull. It is not the least of life’s ironies that this, which we all aim at, is better not quite achieved."
-W. Somerset Maugham
Old Feb 18, 2001 | 12:28 AM
CamaroX84's Avatar
Why aren't they compatible? There is no way it would work? Thanks.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
