Cylinder Head Install Question
Old Mar 13, 2004 | 12:33 PM
Chupakabra-King's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI
Axle/Gears: 3.08
I know this is a stupid question but I haven't ran into a situation like this before . I bought my zz4 engine with the heads removed and today I am putting the heads on when a question entered my mind , How do you know which head is for which side ? Can you bolt the heads on backwards ? I only want to do this once so I figured I would post this question here . There are arrows cast into the heads and I have pointed them toward the front of the motor . I figure it dont really matter what side they go on but hell it dont hurt to ask !
Thanks for the info guys !
Old Mar 13, 2004 | 01:47 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
make sure the holes for the accessories are facing towards the front of the engine.
Old Mar 13, 2004 | 01:57 PM
Petes 84Z28's Avatar
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Um, the heads should be drilled on both ends. The only thing that would make a difference would be if the temp sending unit was installed on one head, and the other just had a plug or a fan switch in the same spot. Otherwise, it wouldn't matter.
Old Mar 13, 2004 | 02:10 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
both heads should be identical, so there is no "driver-side" head or "passenger-side" head. (atleast not for those L98's)
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
