heater control valve.....metal?
Old Feb 19, 2001 | 03:23 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
Does anyone know if there is a heater control valve made that has a higher quality than the plastic ones? (metal?) Mine seems to start leaking at the bottom about every
4-6 months and I have to replace it.
Old Feb 19, 2001 | 05:18 PM
Neo's Avatar
Neo
What do you have radoactive antifreeze? I would recomend checking for heat sources such as the valve covers it sits on, and seeing if you can dispate that heat somehow.
Old Feb 20, 2001 | 02:59 PM
GTA88's Avatar
My 85 Caprice has a metal heater control valve. So yes, they do make them.
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Feb 20, 2001 | 04:25 PM
rezinn's Avatar
When was the last time you changed your antifreeze? Old antifreeze can become acidic and corrode your heater valve, causing those leaks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Nervous2
Oct 8, 2015 10:53 PM
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
dbrochard
Sep 7, 2015 09:41 AM
