Chev/Pont...wazz the diff??
Old Feb 21, 2001 | 06:00 PM
Skip Howard
Guest
Posts: n/a
I've seen references to a chevy 350 and pontiac 350. What's the difference???
85T/A 305/QJ work in progress.
Old Feb 21, 2001 | 06:13 PM
Guest
Guest
Posts: n/a
Ummmmmm... probably the carbs are similar. Maybe lifters too. Thats about it, the rest is entirely different. Pontiac doesnt have big blocks per-se, so the 350 is essentially the same as the larger pontiac engines, meaning its heavy. People usually run the 455, but sometimes the 400. The Pontiac 350 is rarely used, saved for those numbers matching resto jobs.
Offhand, I dont know the bore and stroke. I probably should but heh.. been a while since I looked.
Old Feb 21, 2001 | 06:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The manufacturer.
Seriously, there is essentially nothing that interchanges between the 2. Distributor cap, spark plugs in some years, and not much else. Externally they are different: motor mounts, trans bolt pattern, crank bolt pattern, etc. are all different.
For many years Chevy, Pontiac, Buick, and Olds all produced 350s. In fact, they also all produced 400s at various times too. GM finally eliminated this wasteful practice in the 80s and standardized on the Chevy motor. The other mfrs' motors were perfectly good products; but every one of them is heavier, has more parts, and costs more to make than the Chevrolet. However none of them, inch for inch, runs any better, produces more power, has lower emissions, or gets better gas mileage than the Chevy. So it's no surprise that after the scandal in the 80s - where somebody sued GM when they discovered that their Olds had a Chevy motor in it, and GM's response was that they couldn't put an Olds motor in the Olds becasue they had used them all up in Cadillacs - they started dropping the other "competetive" designs. It is also cheaper to make one thing across the board than 4 different ones that all do the same thing.
ICON Motorsports
Old Feb 21, 2001 | 06:20 PM
Skip Howard
Guest
Posts: n/a
Great info guys,thanks. I thought I might have to worry about that but obviously not!
Numbah-1
Oct 2, 2015 08:27 AM
Vincent135
Sep 28, 2015 10:50 PM
