Vortecs again....Newbie
I have an 82' 355 with a Lunati Bracket Master 2 cam. Its a 292 cam with .480 lift on intake and exh. What would I have to do to a set of cast L31 Vortec heads to make them work with this cam? Thanks
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I dont have all my stuff in front of me, but I think with our cam we can just bolt on the stock heads, check clearances and go-just need self aligning rockers or get screw in studs and guide plates to use old style rockers. Might be a good investment to upgrade springs to aliveate float. I had the whole vortec top end which I sold a month later for some AFR's, but defiately invest in the .015 Fel-Pro head gaskets, worth .5 bump in compression.
Transmission: 4L80E/4L80E
Yeah, you can always replace the bent pushrods later.
Pull the heads apart and check guide-to-retainer clearance. Per http://www.sdpc2000.com/cart.asp?act...art&catid=2172 , "Stock ... out of the box Vortec heads ... are good for about 0.450" lift." You need about .060" more than your at-the-valve lift. While you're at it, trash those truck valve springs and put real springs and retainers on there. Might as well cut the guides for positive-type stem seals. Ever heard of a press-in rocker stud pulling out? Hmmm, might want to consider conversion to screw-in while you've got them apart.
SDPC sells Vortecs with the above mods already performed, good to ~.525-.550" lift (although it's not clear they do the screw-in studs). $700/pr.
If you insist on going with Vortecs, that is...
Thanks for the heads up, could'nt remember exact specs they were good for out of box.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
When I measured my vortecs there was something like .550 clearance between the valve guides and retainer. However, the factory junk valve springs need to go either way.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
But, you still need to check them all. Not just one. All of them.
Chas91Z28
Oct 22, 2015 10:12 AM
monte87cortez
Sep 26, 2015 08:10 PM
