Need help with wiper problems.
Old Feb 23, 2001 | 12:12 AM
Kevin R 82 Z28's Avatar
OK, had to change the lock cylinder on the column yesterday and since then the wipers
will come up a few inches and go right back down. In order to diagnose the problem I dropped the column and check the actual ignition switch before removing the wheel and replacing the cylinder. I'm sure all the wires etc got hooked back up. I would think if I didn't connect something right tey just wouldn't work, not sort of work!?
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
bjpotter
Oct 4, 2015 07:48 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
