buying a 350 rebuild kit what pistons to get ? and parts suggestions.
Old Feb 22, 2001 | 03:10 AM
91camaroRS's Avatar
k im gonna but a rebuild kit from summit like tomorow and i was wondering what pistons to go with. cast, hypereuctic ,forged I dont know what the differences are, but im want to get a 268H comp cam too when i order it unless you guys have any other idea's i want allot of power out of it. I am just gonna put the L98 heads back on it and a performer RPM and holley 750. sound good ?? ....any suggestions
Old Feb 22, 2001 | 03:54 AM
The ODB's Avatar
Pistons do not make power, they only survive it.
If you stay around 400hp or less, you should be able to get by with either cast or hyperutectic pistons.
With power adders and over 400hp it's generally expected to run forged.
For quality forged pistons, look at SRP, Ross, and JE
there are some others, but I'm tired.
Stock cranks and rods are ok to well over 500hp.
good luck
ODB
Old Feb 22, 2001 | 09:37 AM
Polecat's Avatar
For the extra now, get the forged. Because we all know someday you may want tp spray it. Forged pistons will make it handle more go-go juice. Look at the Comp Xtreme line. The dual pattern, with higher exhaust lift will help you. I would say the XE268 would be great for your setup.
Happy building!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Feb 23, 2001 | 08:19 AM
FastBroker's Avatar
I thought he said he was gonna run a Comp 268???
Buy the casts, you'll be fine.
Old Feb 23, 2001 | 08:55 AM
Polecat's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FastBroker:
</font>
So your saying forged now wouldn't be worth the extra $100 or so? My point, do it right now so you don't regret later.
Old Feb 23, 2001 | 10:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Buy the forged ones. For the small difference in the overall cost of the project, they are worth it. TRWs are fine.
There are at least 5 or 6 268° intake cams from Comp that I can think of right off the top of my head. The one you want is the XE268H, not the Magnum 268, any of the others.
You'll probably go faster with a 650 than a 750. I think the number you want is 4776. With a cam that small and stock heads like those you'll never produce meaningful power at a high enough RPM to need the bigger carb. Your peak HP (shift point) should be somewhere around 5600-5800; at that RPM, you'll only be flowing about 540-500 CFM at best.
What about exhaust? If this is a RS you need to replace it from the heads to the street.
ICON Motorsports
Old Feb 23, 2001 | 11:23 AM
The ODB's Avatar
to qualify what I said earlier..
forged pistons will cost much more than $100 over cast or hyper pistons... unless you run the TRW's which are marginally stronger and considered 'junk' in my book.
the last set of good forged pistons I looked at was over $800 per set.
I would never buy TRW's again... been through too many sets now.
I would trust cast pistons with a conservatively tuned NOS system.
ODB
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
hectre13
Aug 26, 2015 08:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
1nastygta
Aug 8, 2015 07:38 PM
