Accel runners on a 305TPI? - mods in sig
Old Feb 28, 2001 | 10:53 AM
Flfinn's Avatar
Car: GTA '88
Engine: 420 Dart SHP
Moving from TPI-section..
The measures are 6.025" and 1.615" for the Accel,
7.250" and 1.470" for the stock.
My TB is stock 48mm and stock intake is ported (radiused) and matched.
Are they too much for my engine? Will my powercurve move too up and end up losing bottom end torque? The cam is set on zero-mark.
-88 GTA 305TPI/T5, 3.45 posi, Crane cams 2032, Edelbrock TES #6872, 3" cat-back, ported+portmatched heads, base, plenum, multiangle valve job, no cat, no air, Haltech E6GM ECM. http://www.helsinki.fi/~kjilehto
Old Feb 28, 2001 | 12:08 PM
theformula's Avatar
Save your money. A rip off if you ask me. Runners don't do doo doo
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
