Do these numbers look ok
Old Feb 28, 2001 | 04:18 PM
theformula's Avatar
Heres a WOT run on my car. All opinions welcome. Do these numbers look ok? I don't hear any knock.
coolant temp- 170.6
throttle sensor 4.39v
throttle posn 99%
engine RPM 5525 RPMS
Vehicle speed 65mph
oxygen sensor 611mVolts
02 cross counts 231
block learn 132
BLK LRN Cell 15
Integrator 128
Idle Air Mtr Pos 73 steps
Desired idle 750RPM
MAP sensor 4.95Volts
Manifold Air Tmp 113.0 F
EGR DUTY CYCLE 0.0%
CCP DUTY CYCLE 74.8%
Battery Voltage 14.0v
Fuel Pump 14.2v
Learned Idle Pos 22 steps
Oil Temp -37.3
Spark Advance 32.9
Knock Sensor 5 counts
Knock Retard 8 degrees
Injector Pulse 11.4mS
Engine Run Flag TRUE
Oxygen sensor READY
Kickdown Pattern ACTIVE
Fuel Cut off DISABLED
CCP Purge ON
Learn Control DISABLED
RICH/LEAN FLAG RICH
Closed Loop Mode ON
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 28, 2001).]
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
