Looking for a 383 Stroker Kit.
Old Feb 28, 2001 | 12:32 PM
Jack's Avatar
I have a one-piece rear seal 350 block (1987 and later) and would like to find a 383 stroker kit. Have found lots of kits for the split seal block but having trouble finding a kit for the one-piece seal block. Any suggestions/recommendations. If I cant find a good kit I would be open to buy the individual parts. Any recommendations for a source for a 383 crank only for the one-piece seal block.
Thanks, Jack
90 Trans Am GTA
5.0 TPI
5 Speed
T-Tops
Old Feb 28, 2001 | 01:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Eagle makes them, either as parts or as an assembly. One of their ESP cranks, SIR rods, JE pistons, etc. IRS carries them, check their web page at www.racenet.net or call Eagle in Memphis. If you call Eagle, talk to Bryan, tell him the guy with the silver 83 Z28 with the 400 and the 305 HO air cleaner sent you. He'll probably charge you extra for that.
ICON Motorsports
Old Feb 28, 2001 | 02:12 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
The BEST 383 kit that I've found comes from Powerhouse out of california!! Their website only has their address, phone number, and email address on it...but at least you'll have a way to contact them!! http://www.enginekits.com
The kit costs $800 BALANCED and you get flat top Pistons (10.3:1 with 64cc), bearings, RODS (don't come with "most" kits you by elsewhere), BRAND NEW 383 stroker crank, BRAND NEW flywheel, BRAND NEW harmonic balancer, and there's more I just can't remember the rest!! You can get the kit with the one piece seal as well!! The entire kit comes with everything you need!! Oh yeah, I was reading a Chevy High Performance magazine and they had an article comparing the balancing work of some of the more "reputable" places and Powerhouse came out on top!! They said the balancing work was so close to perfect that you could basically say it was!! That's where I'm buying my 355 kit from!
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Vortec Intake, Hedman Shorty Headers, Vortec Heads, XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Feb 28, 2001 | 05:02 PM
1989CamaroRs's Avatar
these guys have pretty good prices
http://www.speedomotive.com/
-Stock Tbi 305 with a lot of damn miles
-Edelbrock Z28 TES Headers
-3 inch Catco High Flow Cat
-3 inch Edelbrock Catback
-14x3 Summit Open Element Air Cleaner
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
79 Jeep Cj7
Old Feb 28, 2001 | 05:34 PM
Polecat's Avatar
I did the Speed-O-Motive kit. I like it very well, and was top notch stuff. But I have heard some bad from the guys on Chevytalk.com about Powerhouses kits. Don't know all the details,just info floating around.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
LT1Formula
Oct 8, 2015 08:34 PM
racereese
Oct 3, 2015 03:46 PM
