Machine Shop Time
Old Mar 1, 2001 | 08:32 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Machine Shop Time
I am ready to have my short block done here is what I need.
.30 over
check rods & Crank
purchase & install bearings
deck the block and all the other little things that need done.
I also whant them to build the short block. I will provide the Pistons, rings,cam and timing gear, timing chain
How much can I expect this to cost, what is fair.
Brian Felts
Old Mar 1, 2001 | 09:28 AM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
SWAG: $450
Old Mar 1, 2001 | 10:53 AM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
I'd Say 600-700 depends on what needs to be replaced, and cut, if you have the gaskets, and all want them to degree the cam, oil pump, tanking the block, cam bearings, bored and honed, cut the crank, install the pistons on the rods, have them put it together, and check the oil pressure.
maybe a shade less. but that would be fair with having it done Right, and giving room for odd parts, and bolts.
It's always SOMETHING
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Bryan F
Aug 18, 2015 02:28 PM
Poncho92
Aug 7, 2015 08:15 PM
