I need some serious electrical help here.
Old Mar 1, 2001 | 07:37 PM
RS'er's Avatar
My ECM will not flash error codes. My gauges do not work exept for tach speedo and oil. My temprature gauge is pinged all the way up.
I went through the fuses and all looks good. The ECM seems to be functioning,as it is doing a fine job of controlling idle etc..
Also,the nutjob who had the car before me really screwed it up....My car will start without the key in! Just turn the ignition! Any possible way to fix this????
Thanks!!!
Old Mar 1, 2001 | 09:56 PM
diznuff's Avatar
i had a friend once whos car started w/o the key..you would be amazed at how good he could take his distributor cap off
and as for your gagues and such. you might try using a multimeter and checking the wires and make sure they arnt all cracked and are working
[This message has been edited by diznuff (edited March 01, 2001).]
Fanatic1074
Oct 3, 2022 05:57 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
LC2 TECH
Oct 13, 2015 11:53 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
