What does this A.I.R. crap actually do?
Old Mar 2, 2001 | 09:34 AM
BrianB's Avatar
Now my car passed emissions without a catalytic converter. My question is, if it will pass with a converter and no AIR equipment. By deleting the smog pump and all the other crap that is associated with it. Just so I can clean the engine compartment up.
Old Mar 2, 2001 | 10:28 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
It will probably pass, but you have to get a different cat. Ours are made for AIR injection, and they will clog up without it. You can buy older style catalytic convertors which dont require air injection. My car passed fine as a 305, sniffer test and all. The limit for low and high speed emissions (here in dallas cnty) is 200 hydrocarbons. I passed the high speed (2800 rpm) sniffer test with 77 HC. I passed the idle (800 rpm) sniffer test with 156 HC. The funny thing is that its a small block 400! Granted, I did lean out the carb some before inspection, jsut to make sure I passed...
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Mar 3, 2001 | 01:10 AM
Dan87IROC-Z's Avatar
What the AIR does is inject air into the exhaust to complete combustion. When the exhaust leaves your heads and enters the headers, some of it is still unburned, so the Air Injection Reaction system injects air into the exhaust to burn the rest of the charge before it enters the cat. Air is also injected into the cat to further burn anything that may remain before it exits your tailpipes into Mother Nature. Also, the AIR tuben that enters the cat, aides in the reaction that occurs inside the converter. If you remove these components, unburned fuel will enter your catalytic converter and thus clog it very quickly, I also don't think you'll pass an expection. My friend and I went to have an emissions test done on his 85 Z28 and they did an expection to make sure he had his AIR equipment on there. So its not a for sure thing you can pass.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Johnny*G
Oct 20, 2015 12:37 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
