Flex plate counter weight?
Old Apr 4, 2004 | 08:54 PM
dieseldennis's Avatar
Car: 1987 Camaro Z28
Engine: 5.7 HO TPI
I have a stock 350 HO out of an 87 IROC Z. Is my flex plate supposed to have a counter weight on it? I am not using the origional one and I dont know what it looks like. I am putting it into my 87 Z28.
Thanks all
Dennis
Old Apr 4, 2004 | 11:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yes, if its one of the newer one-piece seal blocks itll have the counterweight.
Old Apr 5, 2004 | 01:13 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Dimented is right.
The 2 pc rear main seal (r.m.s.) blocks have a "counterweight" on the rear of the crank. It's basically done by offsetting the rear flange so more weight is on one side.
When GM went to the 1 pc r.m.s., the rear flange was changed to a full 360*, symmetrical circle. They lost the counterweight on the rear flange by doing this, so they put it on the flywheel instead.
Don't worry about getting them mixed up. The 1 pc r.m.s. cranks have a smaller bolt pattern where the flywheel/flexplate bolts on. They're not interchangeable. Even if you tried to use a 400 flexplate/flywheel it won't work.
Old Apr 5, 2004 | 10:50 PM
Engine: 5.7 HO TPI
Originally posted by AJ_92RS
Dimented is right.
Thanks Alot!
Jee I love this place. I can find out all I need to know from the people with the know how.
Thanks Again,
Dennis
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Damon
Sep 26, 2015 04:29 PM
