ANTHER starting issue
Old Apr 8, 2004 | 06:47 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Ok, built the engine blah blah great and all. (this is the DD 355 setup). Give it a bit of starter fluid to help give it a kick. So my buddy turns it over and it sputters. It slowly cranks. Like its not turning fast enough to turn over.
I put #1 cylinder at TDC, aligned the dizzy to the #1 plug. All the wiring is good. Is this just a case of the battery not carrying enough charge. I might have bad gas . Could that have an effect on starting? YOu can watch the starter fluid spit up through the carb.
Old Apr 8, 2004 | 07:34 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
sounds like you're too advanced. try retarding the timing a bit.
Old Apr 8, 2004 | 08:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
i twisted the dizzy in every direction possible and it never caught. There were points where it would NEARLY catch....
Old Apr 8, 2004 | 09:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like it's 180° out.
Disconnect the 12V from the dist; remove the #1 spark plug; stick your finger over the #1 plug hole; have somebody bump the engine over in little bumps until you feel compression; continue to bump the engine until the timing mark on the balancer just reaches the beginning of the tab on the timing cover. That's #1 firing. Take the dist cap off and see where the rotor is pointing.
Old Apr 8, 2004 | 09:15 PM
Vader's Avatar
Are you certain about the valve timing?
Old Apr 8, 2004 | 09:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I will double check it.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
