I have some GM codes off a camaro I need to know whats wrong, help me out
Old Mar 5, 2001 | 05:07 PM
vadrad's Avatar
Hi guys these codes are from a 87 RS 2.8 5 speed stock, anyways I have been having some problems with the idle bouncing below 1000 and then upto 2000 so I took the codes this is what I got
Flash, 2quick flashes (I assume this is code 12 and means the process of reading codes is starting)
I then got
4 quick flashes, short pause, 5 quick flashes
it flashed this code 3 times is this code 45??
and after it flashed code 12 again to let me know its finished the cycle
I am new to this so I am not sure what can be wrong with my car, can someone please help me out thankyou
Old Mar 5, 2001 | 05:36 PM
82RECAROTA's Avatar
Old Mar 5, 2001 | 05:37 PM
vadrad's Avatar
Thx a lot but what do I do about it??? How can I fix this problem, thx a lot guys
Old Mar 5, 2001 | 06:21 PM
82RECAROTA's Avatar
Old Mar 5, 2001 | 08:57 PM
Vader's Avatar
...or repair the overly rich condition. If the sensor happens to be correct, you are probably running way rich for some reason. What modifications have you done, if any?
Is the air filter clean? Is the fuel pressure too high?
Just curious.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 5, 2001 | 09:07 PM
FastBroker's Avatar
Vader is correct. Code 45 means rich exhaust DETECTED, not necessarily a bad O2 sensor. It's a starting point for your own diagnosis. Have fun!
Old Mar 5, 2001 | 09:38 PM
vadrad's Avatar
I have done no mods its totaly stock, I have had the sensor replaced and it seemed to fix the problem of my car stalling but this was like 5months ago but it never fixed the problem with the idle rpms dropping then jumping then dropping then finally settling at 1000 its been acting really wierd, the air filter is good oil filter is good and all the spark plugs and stuff is good. I am going to try replacing the O2 sensor and the fuel pressure regulator.
Can someone please tell me how long it takes to replace the pressure regulator since I want to know what the mechanics should charge, I am not really good at the stuff myself
evilstuie
Jan 9, 2020 08:29 PM
sonu1975
Aug 11, 2015 08:38 AM
apie2546
Aug 10, 2015 05:43 PM
