coolant use
Old Apr 9, 2004 | 11:16 AM
Beartracks's Avatar
Car: 92 RS
Transmission: auto
coolant use
Long as I'm here, my 92RS uses just a bit of water and I don't find any leaks or other symptoms. It's never been real hot and has low miles. Any oblvious things to check?
Bear
Old Apr 9, 2004 | 02:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You could have a slow drip out of the radiator or a hose or it could be as bad as a leaky head or intake gasket.
Old Apr 10, 2004 | 05:35 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
A leaky intake gasket is usually the culprit on these cars. My car, and many others on these boards have had the same problem. If you can't find a leak anywhere and everything seems dry, more than likely its your intake gasket.
Old Apr 10, 2004 | 05:48 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had a slow leak I could never find either. Then finally I was leaking alot of coolant from my weep hole on my waterpump. Replaced the pump and problem solved
Old Apr 10, 2004 | 06:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
pressure test your cooling system.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
