Bad Alternator?
Old Apr 10, 2004 | 05:44 PM
The_Beast's Avatar
Car: 91 rs
Engine: 5.7 350 :))
Transmission: 700 r4
Axle/Gears: 1996 - 3.42
Bad Alternator?
Ok here are all the symptoms. First off it doesnt start very easily. If it hasnt been long since it was cranked, it clicks a few times before starting. Every once in a while it wont even want to start at all, the battery doesnt even come on. It has a rough idle that fluctuates every few seconds. When that happens the lights go dim for that second and the rpm gauge goes up a little. It does that every once in a while when im driving and the sound quality on the cd player gets bad and the rpm gauge goes up like 500 rpms for no reason. Also, the car quits every now and then while im braking to either stop or turn. It has quit twice while I was just sitting there, once with the brakes on and once while I was in park. I dont think its the battery because we tried charging it yesterday but it seemed to have a good charge. The battery gauge always looks good except when that stuff happens and the gauge fluctuates a little. Sorry if my post is long. Any ideas on whats wrong? Thanks
Old Apr 10, 2004 | 09:11 PM
Vader's Avatar
Fully charge and load test the battery. If you don't have the tester, many places will test it for free (trying to sell you a battery).
Depending on where you go, the alternator output can also be tested at the same time.
Old Apr 10, 2004 | 10:49 PM
The_Beast's Avatar
Car: 91 rs
Engine: 5.7 350 :))
thanx
Yea I do need to go get those 2 tested. Thanks
Old Apr 10, 2004 | 11:20 PM
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
Uh, jump start it? Leave the jumper cables on for a little while and see if you get the same problems.
Old Apr 19, 2004 | 07:27 AM
The_Beast's Avatar
Car: 91 rs
Engine: 5.7 350 :))
Could be Fixed
Well we tested the battery and alternator and they were both fine. But I did have a lose battery cable and we tightened that. Now everything seems to be just fine and im not having any more of that trouble. I also plan to clean any corrosion off the cables just to save any future trouble. Thanks for the help.
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
