compresion ASAP please
Old Mar 6, 2001 | 12:07 PM
mustangs killer's Avatar
How do you figure out the compresion ratio useing a compression tester? Thanks
Old Mar 6, 2001 | 12:11 PM
Bort62's Avatar
stick a Vaccum Line Into the spark Plug Hole and And, while cranking the Motor Over, Suck On the Line.
The # of cranks it takes before you pass out Is your compression.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 6, 2001 | 01:08 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I think a simple question deserves a simple answer.
Calculating Compression Ratio with a gauge is not a very accurate way of doing it. Most gauges have a rubber hose, this means that the air volume inside that hose (usually about 3-4 cc) is added to the combustion chamber volume during a measurement. The end result of his added volume is a reading that is 20 - 35 psi lower than the true reading. Besides indicating the added 2 cc of the threaded spark plug hole itself, these gauges are notorious for leaking as well.
Go to this page for information on how to calculate:
http://www.dragnbreath.com/dragnbrea...2HowtoFig.html
Old Mar 6, 2001 | 01:46 PM
virtual's Avatar
Right. When you do the compression check, make sure all the spark plugs are removed and the injectors are disabled so fuel won't be getting squirted into the cylinders.
The readings between the highest and the lowest cylinders should not be greater than 10%. The closer they are to each other, the better.
Squirting oil into the cylinder(s) will cause the compression to increase some, but there should not be a dramatic increase.
When testing the compression, make sure that the very first pressure jump is close to the max pressure you get. That is, the pressure should not be low on the first crank and gradually increase with successive cranks.
Crank the engine at least 5 revolutions for each cylinder. If you get, for example 160 psi as a max reading after 5 cranks, the first crank should be well over 100.
A leak down tester is probably the best way, but using it calls for having a leakdown tester (two guage arrangement made by companies like Moroso, etc.) and an air compressor.
The actual maximum compression reading you get depends on a lot of variables - mileage, camshaft duration, rocker arm ratio, etc.
Post the numbers after you done the test with all the mods you've done to the engine (if any) and we'll try to help with the evaluation.
Old Mar 6, 2001 | 02:13 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by virtual:
</font>
Hmmm, this post certainly looks familiar. Sorta like one I posted, word for word.
Since I get "beat-up on" when I post one that's wrong, I'd like to get credit when I occasionally get one right.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Mar 6, 2001 | 03:35 PM
the compression varies from 180-190lbs. I hope this helps.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
