seized motor maby? help!
Old Apr 11, 2004 | 06:38 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i just put my 350 in after sitting out in the shed for 3 months. i could turn the motor with my hands and now i cant turn it at all. i am trying to turn it so i can hook up my torque converter bolts. any suggestions?
ps i searched but nothing came up for my liking.....if u no of a post already jsut leave me the link
Old Apr 11, 2004 | 07:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
3 months in a shed shuoldn't seize an engnie.
Pick up a flywheel turning tool. it grabs on the teeth of the flexplate...kinda like a spanner wrench.
Could always bump the starter to verify it'll still turn.
Old Apr 11, 2004 | 07:47 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
we have one at work...ill see if i can use it. otherwise im left with the starter idea and for some reson i dont like that
Old Apr 11, 2004 | 10:02 PM
onebinky's Avatar
I usually get one bolt in on the TC, and then take a long thick screwdriver and stick it in the mounting tang on the TC. This will give you the leverage you need to turn the motor. Go slow with it though to give the engine a chance to bleed off the compression. Use your judgement too, if it feels like the motor is mechanically locked, DONT keep pulling on it. That's only gonna break the tang or break whatever is locking the motor.
Also, is it a serpentine setup? It's possible that a bearing in an accessory siezed, and is holding the belt. If you are just trying to turn it by hand, I'd imagine that a v-belt could prevent you also.
Old Apr 12, 2004 | 12:06 AM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
its a v-belt set up and i have one bolt in already. i tried turning it with a screwdriver on one of the teeth on the flywheel.....i dont have any belts hooked up by the way
Old Apr 12, 2004 | 01:03 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
try turning the motor over by using the harmonic balancer bolt. might help if the plugs are out to reduce compression issues. otherwise the starter idea should work as well.
Old Apr 12, 2004 | 12:15 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
yea but isnt there a chance of the harmonic balancer bolt breaking if there is too much preesure or torque on the bolt?
Old Apr 12, 2004 | 12:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're exactly right; you can break or strip that bolt, or the crank itself, with just a normal non-locked-up motor.
Try the starter first. It will put more torque on the motor than you can. Make sure you have a good hot battery.
Old Apr 12, 2004 | 02:01 PM
xpndbl3's Avatar
Car: 1984 Z28
granted the bolt can strip or break but with the plugs out it shouldn't be too difficult to turn the motor over, but the starter idea should work also, i was just throwing out a suggestion
Old Apr 12, 2004 | 05:23 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
just got a new interstate battery from work
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
