Help my brakes sound like a 4X4 tire roaring down the road
Car: 91 Z28
Transmission: slipping stock 700R4
I recently had to replace the front brakes on my 91 Z28. I had the rotors turned,took everything off packed the bearings and put on Bendix titanium mettalic pads. drove the car and the wheels got hot as heck you could smell them and even a little smoke, so I took them back off and replaced the calipers because I figured they were sticking 163,000 miles original calipers. Put everything back together drove it don't get hot anymore and brakes work fine but they roar like a 4X4 tire going down the road
any ideas
any ideas
try bleeding the brakes...all four!! i have the same thing going on with my car
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Car: yep
Engine: uhuh
Transmission: sure does
Were the bearings good?
Did you check for any scoring on them??
Sounds like a bearing problem.
Are they set too tight??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Not sure but check the rotors. Could you have possibly worped them with that much heat?
Livin the hot rod dream, one day at a time.
lg4
slp muffler
pro flow air cleaner
performer intake
more to come
lg4
slp muffler
performer intake
more to come
Car: 91 Z28
I checked the bearings they looked good no scoring. I don't think they are to tight just tightened them down then backed off to the next notch for the cotter pin like usual.
