MSD 6al need help ASAP!!!!!!
Old Mar 8, 2001 | 12:54 AM
burnoutrpm's Avatar
ok i know this has probably been talked about before ... but in a 89 f-body where would be the best place to put a msd box?? ive looked every where!!! in the cab is where i want it mounted! but cant find even one spot to mount the thing!? joe(msd tech) if you read this HELP!!! or anyone for that matter!!!! btw, the underhood is out of the question... no where to mount it there either!!! HELLLLLP!!!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 8, 2001 | 12:58 AM
Andy89RS's Avatar
Old Mar 8, 2001 | 02:24 AM
Raymond 5.7 89 Formula's Avatar
Check my post in Aftermarket Products Review I asked the same question and got some good replies.
Old Mar 8, 2001 | 09:38 AM
87Z-ya's Avatar
If you want it inside, I used to have mine mounted to the pass side kick panel. It is very noisey though.
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
