car will only blow through defrost vents
Old Apr 17, 2004 | 12:13 AM
zeeboid's Avatar
Car: Cadillac CTS-V Wagon 6sp
Engine: 6.2SC
Transmission: 6 speed manual
my 82 trans am will only blow through the defrost vents... any sugguestions on how to fix that?
also, when i replaced my rear hatch shoks, the shoks i got didn't have the clips on them for the wires that run current to the rear defrost... anyone know a work around, or anything i can do for that?
Pete
Old Apr 17, 2004 | 05:41 AM
ede's Avatar
ede
WAG you have a vacuum leak in the selector system for the hvac controls. no idea about the rear defroster. maybe get a gas strut from gm parts with the correct provisions on it.
Old Apr 17, 2004 | 12:11 PM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
the back hatch shocks should have come with the clips on it. u may have bought the wrong ones. i have the same problem with the front defroster. no matter where i put the selector for the vents it only comes out the defroster vents.
Old Apr 17, 2004 | 01:34 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The HVAC controls are powered by vacuum. If it is not recieving the vacuum it needs it goes into the default setting, which is defrost. You need to make sure everything is hooked up and you don't have any vacuum leaks.
Old Apr 17, 2004 | 02:27 PM
jfawcett10's Avatar
Car: 1987 Formula Firebird
Engine: 350carb
I have a similar problem, mine will blow out the vents normally, but when i shut the car off, the air will still blow, but it will automatically switch and blow out the defrost, and this is while the car is off. So I have to turn the heater off otherwise the air will blow till the battery dies...
But yeah, just my random problem and I do believe i have an HVAC issue...
Old Apr 17, 2004 | 07:23 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
there is a little white plastic vaccuum line that hooks into the firewall by the heater box plug it in,,all will be well
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
