Can someone verify these part #'s for me?
Old Mar 11, 2001 | 04:32 PM
JETHROIROC's Avatar
I'm getting ready to replace my injectors, and I thought I would do the EGR and IAT (or MAT) sensor while I'm at it. This is for a 1990 350 TPI:
EGR Valve: ACD #214-5540
IAT sensor: ACD #213-310
Which gasket pack will I need for removing the plenum and runners:
Fel-Pro #MS 93160
Fel-Pro #MS 93035-1
Any other stuff I need, maybe some Loctite blue or should I use antiseize? Thanks guys.
Old Mar 11, 2001 | 05:05 PM
Guest
Guest
Posts: n/a
Dont know about the EGR and IAT.
The MS93160 is just the plenum and runner gaskets. The MS93035-1 has the intake base gaskets and china walls as well. Youll need the 93160 since you are just doing plenum and runners.
Oh, and with what you are doing you wont need anti-seize or loctite.
[This message has been edited by madmax (edited March 11, 2001).]
Old Mar 11, 2001 | 06:35 PM
JETHROIROC's Avatar
Thanks max. Does the 93160 include a throttle body to plenum gasket and the lower runner gaskets? Thanks.
Old Mar 11, 2001 | 07:13 PM
Guest
Guest
Posts: n/a
Sure does.
Old Mar 11, 2001 | 08:35 PM
JETHROIROC's Avatar
Cool. Thanks, Max .
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
