No Fuel?
Old Apr 28, 2004 | 08:45 PM
Camin89Camaro's Avatar
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
No Fuel?
Hey im new here and have been a member on z28.com for a while but i figured this would be a better place to post my question snice this is a thirdgen board ok... When I start my car it runs fine and will for the first 2-5 minutes? then for a period of about 30 seconds up to 3 minutes or so it acts like its getting fuel then the next second its not then it is again and isnt again.. and sometimes the car will almost come to a stop if you go WOT its will act like its not getting fuel even worse but if you feather the gas it stay running then after its done this it will be ok and will not do it again except sometimes sitting at a light/stop sign but if you stop and put gas in the car it will repeat the process also if you just turn the car off and turn it back on it will not do it again if you do not leave it off for a longer period of time sry for the long first post but i just really want to get this figured out its my daily driven car
Old Apr 28, 2004 | 08:50 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Could be the fuel pump on its way out...welcome to the board!!
Old Apr 28, 2004 | 08:58 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
Thanks im impressed with how fast people reply on this board I though it might be also but ive owned the car 9 months now and its always done it and I figured the fuel pump would went out by now if thats what it was also forgot to add I replaced the fuel filter and my dad rebuilt the injectors I just figured I need to get the problem fixed now plus its imbrassing when friend rides with me and it starts doing it and jerking you around in the car
Old Apr 28, 2004 | 09:05 PM
Engine: 406
I would check the fuel pressure.. if you can ,get a gauge that you can lay on your hood , so you can see if it changes when you drive,
Old Apr 28, 2004 | 09:08 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
ok thanks I will try to do that this weekend also a while back somebody told me it could be a egr valve?
Thanks,
Chris
Old Apr 28, 2004 | 09:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you getting the service engine soon light and if so, what codes are you getting?
Old Apr 28, 2004 | 09:19 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
Nope im not getting any trouble codes just 12...
Thanks,
Chris
Old Apr 29, 2004 | 12:57 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
I might have read wrong, but it sounds like a vacuum leak to me. Sounds similar to how I'd describe one.
Old Apr 29, 2004 | 03:24 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
yeah I have looked at my lines b 4 and they look shot
Old Apr 29, 2004 | 10:53 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
did the car do this before the injectors were rebuilt ....????
Old Apr 30, 2004 | 07:43 AM
Engine: 406
I'm still thinking fuel delivery.. If you had a carb with vaccuum advance disrtibutor then maybe vaccuum.
Old May 1, 2004 | 07:00 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
Yes its done it the whole time ive owned the car thats why we rebuilt the injectors but it didnt work
Thanks,
Chris
Old May 2, 2004 | 03:01 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
I am going to replace the vacuum lines because I was looking at them today and some had tape around them and some were not even hooked up... does anybody have a chart to show were they all go
Thanks,
Chris
Old May 2, 2004 | 03:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Look under the hood over your right shoulder as you are facing the car. There should be a label there with the emission (vacuum line) hose routing. If not, I can post one for you.
Old May 2, 2004 | 03:29 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
Thanks as soon as it stops raining im going to go and see if I can find it I love how fast the replies are
Thanks again,
Chris
Old May 2, 2004 | 03:43 PM
Engine: 406
Tape and all ,huh. Yeah this might be a good place to start...
Old May 3, 2004 | 04:18 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
Yeah im suprised I didnt notice it earler im planing on puttin new ones on this weekend hopefull this will help out some I noticed and idle varation when im in park or nuetrul but not when im in drive or anything else?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
