anybody ever put a fuel cell in a thirdgen?
Old May 5, 2004 | 04:18 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I'm going to be running my nitrous system on a 150 shot next time out at the track,and I'm still running a holley blue pump sucking through the stock intake pump, so I was either going to drop the stock tank and remove the intake pump and replace it with a length of fuel line, or i was going to take out the stock gas tank completely and run a fuel cell somehow.
Any ideas?
I'm doing this because I talked with NOS about my situation, and they informed me that on a single 3/8inch factory fuel line, it is possible to run up to a 200HP shot of nitrous as long as their are no major restrictions in the line and I run two regulaters, one for the nitrous and one for the fuel.
Old May 5, 2004 | 04:24 AM
ede's Avatar
ede
silver solder two AN fittings on the lower rear part of the tank and run 2 lines to a fuel block.
Old May 10, 2004 | 12:30 AM
BFDPerformance's Avatar
why solder? is welding ok?
Old May 10, 2004 | 04:22 AM
ede's Avatar
ede
sure welding will work. silver solder because it's easier and as good if not better than welding it.
Frozer!!!
Jan 19, 2024 04:55 PM
bryan623
Mar 22, 2021 06:43 PM
colton_carlson
Mar 8, 2019 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
