Help me get this timing cover off!
Old May 9, 2004 | 09:06 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
ENGINE IS AN LT-1 BLOCK!!!
I took out all the timing cover bolts, but there is a large pulley bracket attached to the crankshaft snout (where the balancer usually presses on to) it obviouselly holds the crank pulley and has 3 bolt holes in it, but i can seem to remove it even with a puller and lots of force X length.
What is the DEAL? Does the thing press off or what?
Old May 9, 2004 | 09:21 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I think me and my buddy needed to use a 3 jaw puller and a bolt in the crankshaft. A normal HB puller wouldn't work because it was pressing and pulling on the same thing.
Old May 10, 2004 | 11:47 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
thanks, yes we were using the crappy HB puller thing and that was most def the problem! :hail: thank you!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
