I beam to H beam rods - rebalance?
Old May 10, 2004 | 10:42 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I'd like to get a set of H beam rods to replace a set of I beams in a 350. The new rods weigh about 65g more than the originals, I'll be keeping the original pistons. I had this rotating assy balanced before assembling it a while ago.
Should it be nessecary to have the crank balanced again when I put in the new rods?
Thanks in advance
Old May 10, 2004 | 10:50 PM
owned's Avatar
Good *** yes.
Old May 10, 2004 | 11:00 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Take no chances... rebalance it.
Old May 10, 2004 | 11:18 PM
Car: '85 IROC
Engine: LB9
All righty... I'll do that
Old May 11, 2004 | 05:42 AM
ede's Avatar
ede
if the mass of the new rods was equal to or very close to the mass of the old rods you could get by without balancing. very slim change the rods would be the same, or close to the same.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
