190 or 255 gph walbro?
Old May 11, 2004 | 12:13 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
for 91 bird, 305 tbi, 150 shot of juice by time motor is finished, which pump would be appropriate?
Old May 12, 2004 | 10:48 AM
wasp's Avatar
come on guys its a one word answer
Old May 12, 2004 | 10:58 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Aren't both of thse high pressure pumps? (like 60+psi)
But if not and both are correct pressure for the TBI setup, then use the bigger one.
Old May 12, 2004 | 01:36 PM
wasp's Avatar
reason i ask is because i read that the return might not be able to handle the 255 , but i dont know for sure thats why i ask, as for pressures i dont know either ................
Old May 13, 2004 | 01:01 PM
wasp's Avatar
Old May 15, 2004 | 06:13 AM
wasp's Avatar
Old May 17, 2004 | 04:59 PM
wasp's Avatar
i cant believe noone has knowledge to answer this question.....i dont thats why i asked it
Old May 17, 2004 | 07:12 PM
25THRSS's Avatar
The 190 can handle like 600 hp, you could even go lower to a 155 which handles almost 500 hp, the 255 is absolute overkill with 800 hp capability.
Old May 18, 2004 | 02:24 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
That would be true if they were rated at operating pressures but they aren't. They are rated at 0 psi which is no back pressure. Once you install them in a EFI car and set the AFPR to 48 psi or so the rated flow drops. I am running the 255 since it's only $10 more then the 190. My 5/16" return works just fine.
Old May 18, 2004 | 10:19 PM
25THRSS's Avatar
it doesn't make a difference.
Old May 19, 2004 | 01:40 AM
Engine: 4.0L
It doesn't? Well don't think since you buy a 255lph pump you will get 255lph at 48psi because it won't. It you build a 800 hp engine that needs 255lph at 48psi then the Walbrow isn't for you.
Old May 19, 2004 | 01:43 AM
25THRSS's Avatar
It's gonna pump 255gph regardless. Please explain how fuel pressure will have any effect on how many gallons the fuel pump can pump. 800 hp requires roughly the same amount of fuel no matter what psi you are operating at.
Old May 19, 2004 | 08:34 AM
Brent's Avatar
From APE's site:
Clearly volume goes down as pressure increases.
Old May 19, 2004 | 08:57 AM
Engine: 4.0L
Thanks Brent, I was looking for that chart.
Old May 19, 2004 | 10:16 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Thats why you see some of the LS1 TT's with duel 255 intank pumps. Not cause they are pushing 1600 HP
Old May 19, 2004 | 10:18 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I think you need a TBI pump personaly. I dont think the walbros are what you need. Liek the post above its way too much pressure. Thats why I "think"
Old May 19, 2004 | 10:26 PM
25THRSS's Avatar
Either way, his tbi will, at most, push 15 psi. The 255 is gonna be extreme overkill.
Old May 19, 2004 | 10:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I agree with 25th. On a 305 with a TBI to boot, a 255 will be overkill.
gixxer92
Apr 12, 2022 12:09 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
R13_Braz
Sep 18, 2015 05:00 PM
