IT LIVES! But more questions inside...
Old Mar 21, 2001 | 01:54 PM
BlackBowTie's Avatar
Ok, after a new CTS, ignition module, and complete R&R of the all plugs, the car is running. Its idle is rough, like the cylinders aren't firing evenly. It will go through the RPM range, but hesitates/burbles on the way up from 1K to 3K or so. Puffing a bit of white (moisture) and huffs out a nice bit of black when you get the RPM's up. Any ideas? O2 sensor shot? has a new MAP on it.
Also, my fans (both of them) and my HVAC stuff has quit working. No fuses blown for the AC in the fuse block....Is there something else I can check?
Caspar
Jun 19, 2016 11:19 PM
92GTA
Apr 9, 2016 07:39 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
