Put new fuel pump in and car still does not start!
Old May 12, 2004 | 03:02 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
86 ta tpi. My fuel pump does not make any noise when I turn the key on. It cranks but it does not start. No gas comes out of the schrader valve in my fuel rail when i pressed on it. I replaced the fuel pump (a 1 hour job thanks to work done by a previous owner who cut a hole above the gas tank to access the fuel pump). I now have a new pump, pulsator, and fuel strainer and still get no results when i try to start it. I used the code scanner port / diagnostic leads to test the new pump and it works and makes its noise when I give it 12 volts, YAYYYYY!!!!!!!!!!!! B.F.D. because the car still does not start. I still get no noise when I turn the key on. Whats up with this? Any ideas on whats not working?
Thanks!
Old May 12, 2004 | 03:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you check the in-line 20 AMP fuse in the engine bay that supplies power to the fuel pump relay. It should be located near your battery.
Old May 12, 2004 | 04:01 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Trickster you DA MAN!!! I fount the "hidden fuse" by the battery and it was blown. That will teach me to read a troubleshooting service manual before buying new parts. Oh well, I can kiss that 85$ goodbye but now I have good new parts that should give me 100%. BTW, It blew out my replacement fuse too. It seems that I have a section of bare wires at the relay and they are touching eachother, this is blowing my fuse.:hail:
Old May 12, 2004 | 04:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Don't feel bad about it, you aren't the first one this has happened to and you won't be the last.
Old May 13, 2004 | 04:14 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Yeah, Im lucky, I am allowed to make mistakes on my own car
If I had been working at a repair shop I may have had the cost of my mistake taken out of my pay and could have been fired if the customer or boss got too angry with me. Thats why I dont do it for a living.
bryan623
Mar 22, 2021 06:43 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
