My first Firebird Trans Am...
Old May 13, 2004 | 10:56 PM
Yankeerose's Avatar
Car: 1983 Pontiac Firebird Trans Am
Engine: 305 ci V8 LU5
Hey people!
Just bought my very first 83 Trans Am (305 V8) for $10 (you read that right, $10 US - the previous owner just wanted me to take it off his hands) last week and am looking forward to draining my savings to make it run and look great...
Here's my problem though, the car has a stalling/surging problem and idles at about 1100rpm. The Check Engine light has been going on and off intermittently and minutes after that, the car starts to stall. A buddy who owns an 84 Trans Am thinks that the stalling/surging issue may be caused by a faulty O2 sensor. I was thinking of taking it in for a diagnostic and a major tune up to just get everything up to par..
Should I take it to a Pontiac dealer and have them work on it? Is it worth the $$$ spent as opposed to taking it to a good independent mechanic?
Any suggestions?
Old May 13, 2004 | 11:55 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
WELCOME TO THE BOARDS.
Well since your check engine light is on that means your computer is throwing a code. If I were you I would take it to a local mechanic and have them put it on a scanner and find out what code(s) its throwing then go to autozone and buy the part to fix it. Also while your there buy a haynes manual for your car it will help you out alot. Also now would be a good time for a tune up. If you dont plan on working on the car yourself its really a toss up between taking it to the dealer or a local mechanic. I think the things I just listed are to easy to do to pay someone elso for. Good Luck oh and congradulations on getting your first Fbody.
Old May 14, 2004 | 12:08 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A good tune up goes a long way. It may be time for a carb rebuild. I am pretty sure pre 84 vehicles did not have an 02.
Old May 14, 2004 | 12:27 AM
steven90GTA's Avatar
From: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
I would start with a tune up and maybe clean the carb, could need a rebuild
Old May 14, 2004 | 01:28 AM
Yankeerose's Avatar
Thanks! This board has really been great at giving me a crash course on ThirdGens..
Anyway, I've called around town to find out how much shops charged to use a scanner and they've ranged from $75 for independent shops and $160 at the local Pontiac dealership!
The first thing I bought after I got the Trans Am was Chilton's Repair Manual for the 82-85 Firebirds so I think I'll take it in for a scan and try to fix the problem myself depending on how easy a job it is then take it in for a full tune up right after. By the way, the Pontiac dealership also quoted me $600 for a major tune up on the T/A while a pretty reliable local mech says it should cost about $300-$400...so thats still a toss up.
I'll keep you guys updated..
Old May 14, 2004 | 09:42 AM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
Just check the codes yourself do a search on how to do it . Only
requires a jumper wire , or paper clip save that $75., $150. and get a sense of accomplishment. Welcome aboard
Dynodan
Old May 14, 2004 | 10:31 PM
Yankeerose's Avatar
Thanx for the suggestion! I couldn't find any paper clips but I found a short jumper cable and I think I'm ready to check the codes myself..
How accurate are these codes anyways?
By the way, first major problem I had with the Trans Am today - went to fill it up with gas and as I was driving out of the gas station, it stalls and the engine dies! Try to fire it up but it seems like the battery was dead. I was afraid that the starter might have taken a dump but I got a jump and after three tries, it started and ran fine till I got it home. Seems like I might need to shell out some $$$ for a new battery (though its only 5 months old) and while I'm at it, probably get a new alternator too?
Well, I'm off to check the trouble codes...couldn't think of a better way to spend my Friday nite...fiddling with a Trans Am...
Old May 14, 2004 | 11:14 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
CHECK ALL THE WIRING!!...any battery/alternator/ignition type problems...allways check the wiring first....lotso times you will find loose ground/burnt through wires. while a new *insert item here* may fix the problem for a while any bad wiring will cause it to go bad much faster....jsut some food for thought
Old May 15, 2004 | 02:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't think the LG4 (5.0L 140hp) had an O2, but I know the L69 (5.0L HO 190hp) did, because mine has one.
Old May 15, 2004 | 03:30 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Guess I missed anything written about the induction system. What are we working with here? Is it carbed? Is it CFI? I assume the ECm is still there since the engine light is off then comes back on. Just use a paper clip or jumper get the codes and post them. Usually when a car has been around people fart with the vacuum lines and decide to unhook thing that look funny to them without understanding why GM put them there. BTW all 3rdgens came with 02 sensors from the factory at least all produced for sale in the USA.
Now if it were me I'd start looking for that vacuum leak thats most likely causing your problems maybe even back the timing off since the previous owner probably decided to bump the timing up to make her run a bit better.
$50 please
Old May 15, 2004 | 10:11 PM
Yankeerose's Avatar
I'm a total noob at this so I'm not too familiar with the tech jargon yet, sorry..but its a 305ci V8 LU5 with Crossfire Fuel Injection, if that helps any..
Took my jumper cable today and tried to retrieve the trouble codes. With the ignition off, I hooked up pin 5 to pin 6 since it looked like it only had 7 pins (6 on top and 1 on the bottom). I The Check Engine light comes on and flashes 12 three times but then I noticed smoke coming from the dashboard vents and I smelled something smoking so I immediately unhooked the jumper cable and turned off the ignition.
What's going on?
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
