TRW fordge pistons
Old May 16, 2004 | 11:03 AM
devilfish's Avatar
TRW fordge pistons
I thinking of using those in my rebuild. But then I saw that they weight aroun 610 grams!? Can there be balance issue with my new SCAT 9000 crank and fordge i beam rods and can I spin those pistons safely to 6200rpm and 420hp?? Is it worth going to SRP instead?
thanks
Old May 16, 2004 | 11:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes there will be a balance issue. On the other hand, there will be a balance issue no matter what pistons you use; you'll still have to get the assembly balanced, for best possible results.
Yes those pistons will work fine to that RPM and HP level, assuming this is going to be a 350.
As far as "worth it"..... I can't quite see your wallet or your checking account, and I don't know what you're racing against; so it's pretty hard for me or anyone else to definitively declare "worth it" to you, in this build. But IMHO for a street motor with occasional strip duty they'll be fine. I've used them before plenty of times, and gotten plenty good results.
Old May 16, 2004 | 12:47 PM
devilfish's Avatar
ok thanks
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
