Figuring out MPH formula/math
Old Mar 25, 2001 | 05:18 PM
KW87GTA's Avatar
Hi just hopeing someone might be able to help me out here. I know that the standard way to determine MPH is RPM x Tire Diameter divided by Gear Ratio x 336. However, I realize this formula is for a 1.00 ratio tranmission gear. How would one convert this to find out MPH in say a 4th gear .70? Hope someone knows. Thanks.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 98
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old Mar 25, 2001 | 11:13 PM
The ODB's Avatar
gear ratio X .7 X 336
92firebirdguy
Sep 1, 2016 07:53 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Fronzizzle
Sep 8, 2015 12:10 PM
GouldyGTR
Sep 7, 2015 09:05 PM
