upper plenum
Old Mar 26, 2001 | 11:28 PM
Stormshadow GTA's Avatar
upper plenum
i plan on removing the walls in the upper plenum in two weeks ,how do i take it off is it difficult.is there any gaskets i need to replace when i remove the plenum.thanks
Old Mar 27, 2001 | 12:22 AM
jobryan26's Avatar
I had to remove my Plenium today to work on my EGR problem. It's quite easy to remove, more than it looked like. As a suggestion if I may. If you have thought about doing the IAC relocating,AFPR,TB Bypass or Porting your Plentium then is the time to do it since you'll already have everything off. All you'll need is Runner Gaskets if you decide not to remove the Throttle Body like I did. Also it would be a good idea to clean the IAC while you'll have the intake out because it gets corroded in carbon buildup unless you relocate it. Mine was really back. But don't sweat it's not bad, I thought it was fun. But I'm weird anyway. Goodluck!
'87 Trans Am:
(Engine)
305 TPI
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment
(Stereo)
Kenwood Excelon
Old Mar 27, 2001 | 05:08 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
You relocate the MAT (manifold air temp) sensor or IAT (inlet air temp) sensor. You cannot relocate the IAC (idle air control).
But you should clean the IAC while you have it off.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 27, 2001 | 09:12 AM
where is my iac if i am to clean it and what does it look like.if i take off the throttle and remove the walls past the throttle body,do i need a gasket for the throttle body
Old Mar 27, 2001 | 12:03 PM
chris1roc's Avatar
the IAC is under the throttle position sensor(TPS) on the left side of the throttle body. I think that you would need a new gasket.
88 iroc
LB9 305 tpi
k&N, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 27, 2001 | 04:23 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
here's what it should look like.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
MrPackstin
Oct 25, 2017 08:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
