Top Speed....
Top Speed....
Just curious, i have a '91 RS TBI with stock 2.73 gears.
If i were to install a VSS switch and upshift valave, what would my car top out at? Of course my car would need new shocks, tires and brakes, plus a very long stretch of empty and flat road, ala I-5.
I know it would touch 188 mph at redline, but i doubt my car would redline in fourth. Or can it?
[This message has been edited by mostafa3k (edited March 24, 2001).]
I used to have a 91RS 305tbi car(you can see a couple pictures on my webpage). Before i swapped the 2.73 rear for a 9bolt 3.27 i could get to 115mph no prob. So i have a feeling you'd be lucky to get to 135-145mph??
Does that sound right? Somebody else help out here.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
I doubt a 305TBI could hit 145 considering thats about the top speed of a 350TPI. Remember it may take 20 horsepower to go from 100 to 120, but it may take 50hp to go from 140 to 160mph. Drag is an exponential function of speed.
Shaun
92 B4C 350TPI
AFPR, Underdrive Pulleys, Hypertech Thermomaster, Dynomax Cat-back, K&N's, Airfoil, Ported Plenumhttp://www.angelfire.com/wi/lhelm99
Shaun
92 B4C 350TPI
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have an 87 LB9 auto IROC and my speedo is under reading for some reason (anyone have any ideas how to fix this?) but I have done an indicated 125mph and converted over to proper readings it's in the region of about 145/150mph. I could maybe get an extra 5mph but the car lacks power to accelerate it much in 4th as the gear is so high (2.77s at the back too).
Youre probably able to do about 125-130mph.
I'm not sure though.
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods due in March:
K&Ns
RAM Air
Air foil
AFPR
Hoping to get a couple of tenths with that lot
Rob
Mods
K&Ns
RAM Air
Air foil
AFPR
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Give me a damn break RMK. 150 in your 87?? I would say 130-135 tops if you gearing gives top end at hp peak. Anyhow, who tries to top out a 10 year old 190 hp car anyhow. It is just foolish.
I have a 82 Z 3spd Th-350 and I had my car up to 230km/h I think thats about 140mph I raced a mustang, thats what he said I was going, as well as a 89 TA my speedo only goes to 85 mph so dont know for sure. And my car was reving about 6500, its the second one in my sig
Car: 84 TA
Engine: 305 L69
My 84 TA 305 carb 5 spd reached 235kms & still climbing befor running out of road!
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
Removed A/C A.I.R. Hdflap
H/made cld air induction
K&N
Otherwise STD
5 Speed manual
K&N
Otherwise STD
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
what engine you got? 305 right?
