fuel pump relay
Old May 27, 2004 | 02:13 PM
Bammargera7152's Avatar
Car: 1982 camaro z28
Engine: 5.0 liter v8, cross fire injection
fuel pump relay
Im planing on replacing my fuel filter and i heard theres a lot of fuel that comes out of the line when u take it off and i wanted to know where the fuel pump relay was to relive the pressure.
Old May 27, 2004 | 02:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Just take out the fuel pump fuse, start it up until it dies, then replace the filter.
It's best done with the fuel tank fairly empty, and a catch pan handy even though you've relieved the pressure.
Old May 27, 2004 | 02:42 PM
where is the fuel pump fuse?
Old May 27, 2004 | 02:52 PM
five7kid's Avatar
In the fuse panel. Left of the driver. Underneath the dash.
Old May 27, 2004 | 02:59 PM
can i just disconnect a battery cable?
Old May 27, 2004 | 03:05 PM
DJXero's Avatar
Car: 1992 Camaro Z28
You'll need to start the car to relieve the pressure. you can unhook the battery and drain the fuel manually, but that's a lot of fuel to let drain out. If you can't find the fuse in the fuse box, try near the battery terminal mounted to the side of the engine bay(I'm sure I'm wrong, and that it wasn't like that for the older cars, but it's worth a shot)
Old May 27, 2004 | 03:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Five7Kid,
That fuel pump fuse in the fuse panel that you are talking about does not apply to all of the 3rd gen cars. So it might not apply in his case. One of the best ways to relieve pressure in the system is to open the gas cap. some fuel will come out regardless because of the fuel trapped in the lines.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
