N.Y. emissions-can this be?
Old May 29, 2004 | 09:07 AM
briggette's Avatar
I took my car (92 firebird) in for an inspection on Wednesday. The car failed. Then numbers were HC .94 OC 14.47 NOx 2.39.
He says it was probably the EGR valve. The car wasn't coding so we just cleaned it out.
I brought the car back two days later. Now the numbers are
HC 1.63 OC 29.49 NOx 1.81. Can this be?
Same shop and same machine.
O2 sensor is about a year old and the plugs and wires maybe 5 months.
Old May 30, 2004 | 01:14 PM
Vader's Avatar
How old/effective is the cat converter? Is the A.I.R. pump and valving system functioning properly?
What are the new emissions limits in NY, anyway?
Old May 30, 2004 | 01:21 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Has the car sat? Did you warm it up good? What do you have in it for gas etc.? I am inclined to agree with this guy and say that, most likely, the air isn't hitting the cat.
Old May 30, 2004 | 01:36 PM
briggette's Avatar
The new limits are
HC 0.80 CO 15.00 NOx 2.00
I had just regular gas in it and the day in between I put an injector cleaner in. I had dropped the car off so I'm sure he didn't warm it up.
I'm getting a sticker but I still just want to understand how the numbers can vary so much.
I guess I should look into the cat being the problem.
Old May 30, 2004 | 05:30 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by briggette
... I had dropped the car off so I'm sure he didn't warm it up.
If he put it right on after just starting it, that would be your problem. The catalyst has to reach it's operating temperature so that the catalyzation occurs.
Old May 31, 2004 | 10:34 PM
AllGoNoShow's Avatar
Where in NY are you that you have to get your car sniffer test? Nyc area?
Old Jun 1, 2004 | 01:35 PM
briggette's Avatar
Long Island....
I had the car tested today someplace else and it still fails so I guess it is the car.
derbyman99m
May 22, 2012 11:53 PM
craftybob
Mar 27, 2012 08:41 PM
73duster
Apr 20, 2010 08:00 AM
73duster
Exterior Parts Wanted
Oct 4, 2009 03:54 AM
scott's85T/A
Mar 16, 2002 11:55 AM
