Canister question
Old Jun 1, 2004 | 11:37 PM
87Formula4bbl's Avatar
Car: '87 Formula
Canister question
It's been a longggg time since I've taken all this stuff out (some of it, I dont know why), and I'd like to know if anything needs to be done to hook the canister back up (traps tank fumes, correct?). I see here, looking at a diagram in my Haynes manual, that it originally ran to a Purge TVS (not sure what TVS is, but sure, I dont have it anyhow) and then to a Canister Control Valve (also done have). Since I no longer have these items, is it ok to just run a hose from the canister to a port on the carb?
I recently read about gas evaporating (almost in the gallon/week range!!) so I'd like to get this back on, trying to get my gas mileage up.
Thanks,
Ben
Old Jun 2, 2004 | 09:10 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Tvs is a thermal vacuum switch.
You need both valves for you system to run properly. Otherwise you will have a vacuum leak at all times. You also need the valves to meter the amount of fuel vapor entering the engine.
Old Jun 2, 2004 | 11:28 PM
Car: '87 Formula
I'm assuming the TVS allows the canister to purge once it reaches a certain temp? I think the purge TVS sits atop the thermostat housing, right? I still have that on there, so no problems there. I think a vacuum hose runs into that from the carb, then from the TVS to the canister. I noticed the canister has a vacuum operated valve, which I assume allows it to purge when it sees vacuum (from thermal vac. switch).
Ok, no problems there, it looks then as if all I need is that Canister Control Valve, as seen in the pic. I'll go to the junkyard and pull that off. Man, I almost hate to rerun all these lines in my engine bay but hey if it means better mileage then its probably worth it. It was so cleeaannn looking tho
edit: Whoops, no vacuum line directly to TVS from carb, but I think that line feeds both the can. control valve and the TVS? Either way, is that how it works, still?
Old Jun 3, 2004 | 03:38 PM
dankhound's Avatar
Car: 91 RS
Thats pretty close to how it works. The purge valve is controlled by a solenoid that is ecm controlled not by the tvs. The tvs is just a valve that only allows the system to purge once it has reached a certain temperature.
Old Jun 3, 2004 | 10:35 PM
Car: '87 Formula
Does anyone know if it would be a bad idea to cap off the fuel line where it's supposed to go to the canister? I would think....yes....but, I'm not positively sure how the gas tank works with pressure.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
