Piston mixup
Old Jun 6, 2004 | 03:51 PM
Uwe 1985-IROC's Avatar
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Piston mixup
Hi to everybody !
I had bad main bearings ( https://www.thirdgen.org/techbb2/sho...readid=240916& ) and therefore I am changing all bearings ( cam, crank, rod ) and the crank ( which is destroyed, too ). Now, all pistons are out and today I started cleaning them. I recognized, that the rod-caps don´t look the same. ( I think they have different weights, is it for the balancing ? ) - Now the problem is : I marked every piston and rod-cap for the proper reinstallation and now I found a marking from the engine-rebuilder, too. Piston 1 and 7 are mixed up. Wouldn´t that hurt tha balance of the engine ? - Can I install piston 1 in bore 7 and vice versa or what should I do ???
Thanks, Uwe
Old Jun 6, 2004 | 05:01 PM
ede's Avatar
ede
they should weight the same, or close to the same. if you never had any vibration problems i'd reinstall them where i took them out. i've seen lot of engines have marks that didn't corospond to where the part came from.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
