Friend with heat related problem...
Old Jun 9, 2004 | 03:15 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
A buddy of mine has a thirdgen with an l98 that has had a problem that he says is heat related. Car runs fine for short trips but he says if the car is run for a while, or sits still while running and gets hot then it does something strange. It will shut down on him, only while hes pressing the gas pedal. He says it makes some sort of sound and if hes quick enough to react that he can take his foot off the gas pedal and it will continue working if hes light on the gas. But sometimes it shuts down all-together. Any thoughts??? I was thinking ignition module but he says he replaced that a couple months ago. Sounds strange....
Old Jun 9, 2004 | 03:16 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
Also; he says hes not possitive if its heat related. So I guess any input would help.
Old Jun 9, 2004 | 05:50 AM
ede's Avatar
ede
modules fail hot and just because it's been replaced doesn't mean it's still good. does it restart after it dies? is the tune up good? no codes?
Old Jun 10, 2004 | 01:39 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
He says it usually restarts after sitting a while, but a couple of times he has had it towed. Tune up is good he says and he doesn't know about codes so....
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Lbibb
May 5, 2016 12:00 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
