fuel pump relay.
Old Jun 10, 2004 | 01:37 PM
MichaelShaub's Avatar
Car: 1988 Notchback GTA
Engine: 350 L98
Transmission: 700 r4
fuel pump relay.
i needc to know which relay is for the fuel pump.. i get two different wire combinations from different people
one guy says
"Remove the fuel pump relay, but keep the harness connected. This is
____located on the top of firewall, driver's side, on a relay bracket. It's the leftmost
____relay, with a connector that has these wires: Tan/white, black/white, green/white,
____orange, orange. "
another says
"Here's how to identify the fuel pump relay. It has the following wires going to it:
ORG
TAN/WHT
GRN/WHT
BLK/WHT
RED
The ECM tells the fuel pump to prime."
who is correct? i need to know to check the wires on the circuit..
Old Jun 10, 2004 | 05:29 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Just pull one out and see if the car starts and keeps running. The one that doesnt let the car run is the fuel pump relay.
Old Jun 10, 2004 | 05:54 PM
3rdGenBlackBird's Avatar
Pull out a couple of relays that you think might be the right one and use a jumper wire across the larger terminals on the harness with the key 'on' and engine off. Listen for the pump.
It's easy to move them around so the relays might be in a different order from what a manual says.
Laters,
Scott
Old Jun 10, 2004 | 06:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The oil pressure switch will keep powering the fuel pump so the car doesn't die. It will have to be unplugged as well (located just about the oil filter).
Old Jun 10, 2004 | 08:18 PM
Engine: 350 L98
wrong idea..
the car will not even start.. im trying to figure out what it is.. a short .. relay/. when i turn the key to on to hear the fuel pump prime it does not... in addition to not hearing the pump prime if i leave a certain relay in the 20 fuse near the batter will pop as soon as the key is turned. that is why i ask the correct combination of wires to the relay to help myself better trouble shoot why my pump will not prime and will blow the fuse thats why i need to kmnow what the relay is to trouble shoot the wiring..
also if the MAf is burned out or one of the maf relays will that cause that 20 amp ecm fuse to blow near the battery?
i check ed the battery and alternator.. the battery was fine.. the alternator is faulty.. i dont really think that would cause that fuse to pop but you guys know more than i do.... out of 4 birds only one ever had a starting problem that i couldnt figure out..
im stumped..
Old Jun 10, 2004 | 08:22 PM
Engine: 350 L98
oil pressure switch..
where ecactly is it ? i get two responses on this too..
i have an 86 trans am 305 tpi currently.. i thought i seen on my notchback but i didnt think i saw one when i was looking at this one.. could this be the year that it is by the distributor?
also if this switch failed or lost a wire would it blow the fuse? (grounded wire or what not)
Old Jun 10, 2004 | 09:14 PM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
remember to check the fuse by the battery in the passenger fender, b4 u do the relay, i just had a problem where my pump wouldnt turn on and changed the relay, but nothin, and it was the fuse.... my post is in the eletrical
Old Jun 10, 2004 | 09:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: wrong idea..
im stumped..
That's his whole problem Jay, the fuse you are talking about keeps blowing.
Old Jun 10, 2004 | 11:17 PM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
ahhh i c i am sorry , g/l with that
Old Jun 11, 2004 | 09:15 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Have you checked the wiring by the ECM for shorts?
I had Lo-jack installed in my car awhile ago and the installer did a **** poor job connecting the lo-jack to the ECM.
He ran a power wire under the passenger side door sil and didn't enough length so instead of running a new wire, he just got another piece and connected the two together with electrical tape. It finally contacted metal and kept blowing that fuse.
Scott
Old Jun 11, 2004 | 09:21 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Scott,
Your mentioning the Lo-Jack system reminded me of a guy down in Miami, Florida who had that system installed in his nice shiny new porsche. He came out the next morning and found the Lo-Jack system sitting in the parking spot where he had parked the porsche. The car was never found. Hope this doesn't happen to you.
Old Jun 11, 2004 | 10:04 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
LOL! Me too!
Sounds like it was an inside job too me.
At least he knew where his lo-jack was
Old Jun 11, 2004 | 01:10 PM
Engine: 350 L98
checking for shorts
how do i check for shorts with a voltmeter?
Old Jun 11, 2004 | 02:02 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I think you need to have the volt meter connected to both ends of the wire. Any break will show up as no voltage.
Old Jun 11, 2004 | 02:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have the meter set to OHM's to show continuity. This how to determine a break in the line.
Old Jun 11, 2004 | 02:26 PM
dankhound's Avatar
Car: 91 RS
If you disconnect connecters in a circuit you can narrow down where the short is located. When you get to a connecter that doesnt blow the fuse you have a problem between that connecter and the ground side of the circuit.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
